Optical fibre internet not working
  • June 17, 2025
  • 37 Bekeken
My internet is down since last 5 hours. I have a optical fibre connection with huawei modem and zyxel t-56 as connector. PON light is blinking continuously and internet icon is showing red. Have tried reaching to customer support but no luck there.
Can someone please help on this.
Hi ​@maheshy.49, welcome to our community!
The cause was found last night and adjustments were made immediately. This fixed the earlier problems with Internet, TV and Fixed Call in region Netherlands. Should you still have no connection, please disconnect the modem and the media converter (and any Wifi extenders) from the power for at least 10 seconds. If this doesn't work, can you give the modem a hard factory reset by pressing and holding the button on the back of the modem for 30 seconds?
If you still can't get online after this, please send me the status of the lights on the modem and ONT. Then I will have it investigated further! Make sure your profile includes your postal code, house number, date of birth and the last 4 digits of your bank account number, otherwise I won't be able to investigate. Thanks in advance.
1 reactie
