I couldn't connect our Smart TV to Wifi
  • April 28, 2023
  • 273 Bekeken
Our internet connection was installed last Wednesday. All devices (phones,tablets) in our house can connect to Wifi. However, our TV couldn’t connect. It shows IP setup failed. I have tried all the troubleshooting that I know. I had reset the TV also, turn the the modem on and off.
IP address , gateway, DNS Server shows 0.0.0.0.
Could you please me to fix this issue?
Hello @Calix
Do you have Fiber with a Zyxel-T54?
You could try to log in in the web interface via 192.168.1.1 with admin and the Login Password behind the router, turn 5 GHz off in WiFi instellingen and try to connect.
Another option is go to the menu, netwerkinstellingen, draadloos and you'll see beveiligingsmodus at the bottem, choose WPA2-PSK and save it.
1 reactie
  • April 28, 2023
Hello @Calix
