Hello,
Please can you advise on how to fix my no internet connection using fibreglass:
- Huawei convertor with green power, no PON, red flashing LOS, green LAN
- Zyxel T-56, green power, green 2.5G WAN, red internet, no LAN, green 2.4G and green 5G
I’ve tried the following but still no internet:
- turning off the power to both boxes and restarting the convertor first, then the modem
- turning off the power to both boxes, reseating all the cable connections, and turning on the converter then modem.
The internet hasn’t worked on 19 November 2025 since midday, and I’m low on data allowance for the phone, while working from home.
Thank you,
MA
