How can I block access to unsafe websites for my children?
  • January 21, 2022
  • 227 Bekeken
I want my WiFi network to be more secure, I want to block access to sites that are not safe for children
Beste antwoord door Demi van Odido
@Abdulrab93 There are two ways to block sites. You can block sites through devices and apps. In this blog we give you more information about which apps you can use and how you can block sites for Android and iPhone. The other option is to use parental control to block sites. On this website you read how you can do this. For this option you need to login in our Zyxel T-50 modem. Hopefully this helps for you!
Demi van Odido
  • January 23, 2022
sublimerote
For me the link “this blog” opens this thread again instead of a blog, so I don’t know whether I’m duplicating info, but another(?) option to consider is a DNS service which offers parental controls.
Examples:
  • NextDNS (“free”, but paid when used a lot)
  • OpenDNS FamilyShield (free for simple use, but paid when you want to configure more yourself)
Boris
  • January 24, 2022
You are right @sublimerote! The blog which was posted should be this blog: Website blokkeren op Android en iPhone. I’m sure with the answers provided, a solution can be done.
