Connection lost in specific timeframe
  • January 18, 2026
  • 26 Bekeken
Hi there,
Since last Thursday, I’m facing a weird problem. During a specific timeframe (from sunset till midnight), I’m not able to connect to IP cameras connected to a dvr in another country. The cameras can stream if I connect via 5g (mobile data) with no problems. Only, via WiFi connection no connectivity.
My Odido router is ZYXEL - EX5601-T1
Troubleshooting:
Restart router, Factory reset router, called Odido technical support, problem still exist.
Does anyone have a clue?
Beste antwoord door Safrioune
Yes, everything work fine & as usual!
2 reacties
  • January 18, 2026
Hello ​@Safrioune
And all other devices wired and wireless have no issue? So rhe internet connection works fine?
  • January 18, 2026
