connection issue Den Bosch
  • sep 23, 2023 9:06 a.m. UTC
  • 90 Bekeken
Red globe light on Zyxel T-54, no internet connection for more then 12 hours. Den Bosch, Hinthamereinde.
Beste antwoord door pviktor
Hello,
Resolved in the meantime, now it is fine.
I have fiber connection, the cable goes into the WAN port. The internet globe was lighting red, Power and WAN was lighting green, 2.4G and 5G was blinking green.
I could connect to WiFi, but there was no internet. Restarting more times hasn't solved the problem. 15 minutes after posting, the issue has been fixed by itself.
Thanks for the tip, next time I will check this as well.
2 reacties
  • sep 23, 2023 9:25 a.m. UTC
Hello @pviktor
Do you have a Fiber or DSL connection?
In case of Fiber which lights are on or blinking on the mediaconverter and is the cable from the mediaconcerter going to the WAN oort of your router?
You can also look in your Odido account under meer, storingen if there is an outage in your area.
  • sep 23, 2023 12:43 p.m. UTC
Hello,
