Red globe light on Zyxel T-54, no internet connection for more then 12 hours. Den Bosch, Hinthamereinde.
connection issue Den Bosch
Beste antwoord door pviktor
Hello,
Resolved in the meantime, now it is fine.
I have fiber connection, the cable goes into the WAN port. The internet globe was lighting red, Power and WAN was lighting green, 2.4G and 5G was blinking green.
I could connect to WiFi, but there was no internet. Restarting more times hasn't solved the problem. 15 minutes after posting, the issue has been fixed by itself.
Thanks for the tip, next time I will check this as well.
