T-mobile thuis installation delayed
Hello,
I have ordered T-Mobile Thuis (100 Mega Glassfiber subscription). A person came over to my home on 30 October to look at the connection to the fiber network. He had to come back with a colleague to route the fiber under the floor. Since the 30th of October, I have not heard of T-mobile at all ! What’s going on! The installation is promised to be operational by 29 November. I would appreciate getting some clarification about the next steps.
Thank you
Regards, apleon
Beste antwoord door Brian
Hi @apleon, I checked with our technical department and the request is still on-going on the grid operators side. A request such as this usually takes around 6 weeks because of licences the grid operator might need from the city. These licences are usually for permission to dig in certain spots in the public space. We requested a wish date of 29-11 so I expect you will receive a notice with the definitive date before this time. Apologies for the delay!
12 reacties
  • November 13, 2019
Hello @apleon
Please edit your post and remove your T-mobile thuis klantnummer to prevent misuse of it by other people.
If a moderator needs personal information he will always ask you to send the details via private message.
  • November 14, 2019
How can I edit the message?
  • November 14, 2019
Right side in the botten of your post you see 3 dots click on them and then edit @apleon .
  • November 14, 2019
Thank you
Regards, apleon
  • November 18, 2019
Hi @apleon, I’ll gladly give you an update! They need 2 mechanics at the same time to safely realize the connection under the floorboards which makes it harder to plan. It is taking a long time however so I will inform what the hold-up is and get back to you (hopefully tomorrow).
  • November 19, 2019
Hi Brian, Thank you for the update. I look forward to your further feedback.
  • November 19, 2019
  • November 19, 2019
Hi Brian, Thank you for the clarification. I will be waiting for this notification. When can I now reasonably expect to get the full installation done? I assume that until then the internet connection will be still provided by Tele 2. Please confirm.
HI @apleon,
Until we provide you with a working connection, Tele2 will be your internet carrier. Because you’ve selected the ‘Overstapservice’, we’ll make sure you get to keep your current signal! Hope this helps. :smile:
  • November 22, 2019
Hi Jason Ok very well
  • November 27, 2019
Hi all,
We are getting close to the wish date of 29 November and nothing has actually happened (no contact, no appointment). It is very disappointing. I urge you to clarify this irritating situation which has already been going on for much too long.
Piotr
  • November 29, 2019
Hey @apleon,
Sadly enough your order got delayed due some technical issues. I've send our technical department a message with the question when your order will be ready. As soon as we'll receive a message, we'll contact you right away. I'm so sorry for the inconvenience. Luckily in the meantime you can still use your connection from your current provider.
