I have ordered T-Mobile Thuis (100 Mega Glassfiber subscription). A person came over to my home on 30 October to look at the connection to the fiber network. He had to come back with a colleague to route the fiber under the floor. Since the 30th of October, I have not heard of T-mobile at all ! What’s going on! The installation is promised to be operational by 29 November. I would appreciate getting some clarification about the next steps.
Thank you
Regards, apleon
Beste antwoord door Brian
Hi @apleon, I checked with our technical department and the request is still on-going on the grid operators side. A request such as this usually takes around 6 weeks because of licences the grid operator might need from the city. These licences are usually for permission to dig in certain spots in the public space. We requested a wish date of 29-11 so I expect you will receive a notice with the definitive date before this time. Apologies for the delay!
Hi @apleon, I’ll gladly give you an update! They need 2 mechanics at the same time to safely realize the connection under the floorboards which makes it harder to plan. It is taking a long time however so I will inform what the hold-up is and get back to you (hopefully tomorrow).
Hi Brian, Thank you for the clarification. I will be waiting for this notification. When can I now reasonably expect to get the full installation done? I assume that until then the internet connection will be still provided by Tele 2. Please confirm.
Until we provide you with a working connection, Tele2 will be your internet carrier. Because you’ve selected the ‘Overstapservice’, we’ll make sure you get to keep your current signal! Hope this helps.
We are getting close to the wish date of 29 November and nothing has actually happened (no contact, no appointment). It is very disappointing. I urge you to clarify this irritating situation which has already been going on for much too long.
Sadly enough your order got delayed due some technical issues. I've send our technical department a message with the question when your order will be ready. As soon as we'll receive a message, we'll contact you right away. I'm so sorry for the inconvenience. Luckily in the meantime you can still use your connection from your current provider.
