Glass fiber connection
Hello,
The glass fiber connection point has been laid/installed in my house and I’m wondering when T-Mobile will contact me when the installation or the connection will be up?
Thank you
Hello @Marcodendolol
When the Fiber connection point has been installed in your house and everything outside is finished so the connection is ready for use than you'll automatically receive a message from Guidion via email/sms so you make an appointment for the installation of the mediaconverter and router.
  • April 24, 2023
  • April 24, 2023
Hello Waqqas,
Do you have an estimate day for the area? 3014CD, Rotterdam.
Thank you.
Hi @Marcodendolol, thanks for this topic! I have checked your order right away, I can see that you can contact KPN NetwerkNL at this point. You can do so via https://www.kpnnetwerk.nl or by calling 088-0063744 (option 2, 'nieuwbouw'). KPN NetwerkNL will inform you further about the situation. Good luck!
