Sometimes, when I switch on my TV box (from standby) there is a screen with white noise.
The only way to stop this is to pull the power cable from the TV box and wait for it to reboot.
This happens maybe 1 in 10 times switching on TV box.
Thanks
Thanks
Hi
Great that you already tried resetting the TV Box, that pretty much covers the box itself. Could you try rebooting the modem by unplugging the power cord for about 20 seconds whilst unplugging the ethernet-cable as well, please? When the error message shows up on screen regarding no internet (no IP), re-plug the ethernet-cable. If that still doesn't solve the issue, try a factory reset. Also try factory resetting the TV Box. Do keep in mind however, that a factory reset erases your recordings, should you have a TV Box with a recorder.
Have you checked the wiring yet? Is the HDMI- cable plugged in correctly and firmly and is the UTP (ethernet-cable) connecting modem and TV Box still undamaged? You could always try a different port on the modem. Which modem do you have? If it's a Zyxel, try any of the 4 ports on the back of the modem. That way we'll know for sure which probable causes to exclude.
We'll find a solution, I'm absolutely positive!
