Hi,
when I try to watch a rerun on tv I hear a sound but the bronze stutters. how can I fix it??
Bekijk origineelHi,
Bekijk origineelHi
In any case I would advise you to perform a factory reset of the TV Box by putting a pin in the hole on the back of the TV Box for approximately 10 seconds. Afterward you will see the TV Box restarting automatically. You will be able to find the hole that reads ‘reset’ just below the USB port.
Eager to hear if it allows you to fully enjoy The Bronze again!
