Zyxel T-56 usb speed
I have attached a USB SSD to the Zyxel T-56 modem and the write speed is extremely slow - under 1MBps
While the read speed seems to be decent:
Firmware version is V5.70(ACEA.0)T56C_b10_0130
Beste antwoord door Okidokidough
I see this complaint more often about the Zyxel routers odido is using, I don't think you'd really be able to improve on it. If you really need fast network storage, you're better off getting a NAS. if its just about storage you could probably get a cheap 2nd hand and be just fine, just make sure it's still supported with at least security updates by the manufacturer.
Forum|alt.badge.img+2
  • August 8, 2024
  • August 8, 2024
It is not advertised to use the router as file server. For small logfiles it is ok, but it can not replace a normal NAS.
  • August 9, 2024
Thank you both for your replies. Definitely, NAS is the way to go. My expectations are not similar to the ones of a NAS, I just noticed the big difference between read and write. I believe the read speed is decent
