Good morning Team, I ordered a 1gbit connection which i was given a Hawaii modem (which i cannot work due to work in security) as such I would like to connect my connection directly to my Dream Machine Pro.
I have been told and from what i have read this can be done either via PPPOE or DHCPv4. Can you assist with the settings that would need to be put into my dream pro to have this connected.
I have presently followed the settings
Beste antwoord door louisL
I am not a Unifi expert (I have only a few trusty AP’s). But here are a few comments that should get you started:
For Odido you will need to use DHCP that setting looks correct in the screen you showed.
Select VLAN300 as the upstream interface (set VLAN id to 300)
If you connect the dream machine to the ONT using an ethernet cable the above should be enough to get you started. I you want to replace the (Huawei) ONT I need to know what technology (GPON/ XGSPON) is used and what type of ONT (SFP in the Dreammachine OR an external ONT with RJ45) you want to use to be able to find a suitable ONT
Bestand scannen voor virussen
