Odido + iOS Lockdown mode: roaming not working
  • apr 10, 2026 8:03 a.m. UTC
  • 177 Bekeken
Odido NL physical SIM (Business Ultimate abbo) on iPhone 17 Pro in EU/non-EU roaming works normally until Lockdown Mode is enabled.
With Lockdown Mode on, roaming network name appears, but voice service fails and signal bars stay empty.
Disabling Lockdown Mode restores service immediately.
Same line works on iPhone 13 mini on the same roaming networks.
Other Odido number on another iPhone 16 Pro exhibits exactly the same behaviour.
Same is valid for Odido eSIM (when trouble started - ordered physical SIM to compensate, but problems persisted).
All software is up to date: iOS 26.4.1, latest carrier settings (Odido NL 69.0).
All 3 iPhones bought from Apple NL, no carrier lock etc.
Multiple resets (Network settings/Full reset) did not help initially, only after 4th reset and starting the Lockdown mode I discovered this.
Please check whether there is a known compatibility issue between Odido roaming/cellular services and iPhone Lockdown Mode, and whether this can be escalated as a carrier compatibility issue to Apple.
Beste antwoord door kolmanovich
Workaround: After chatting with Apple Support, I found out that there’s an option in Lockdown mode hidden way down:
Go to Settings - Privacy & security - Lockdown mode (turned on) - scroll down - Turn on switch "cellular network 2G/3G".
After this roaming starts to work normally.
Information’s not on Apple’s website and according to them “it will be published shortly”.
  • apr 10, 2026 8:44 a.m. UTC
  • apr 10, 2026 8:57 a.m. UTC
Hi ​@kolmanovich ,
See support Apple page.
  • Wireless connectivity: Your device won't automatically join non-secure Wi-Fi networks and will disconnect from a non-secure Wi-Fi network when you turn on Lockdown Mode. 2G and 3G cellular support is turned off for iPhone and iPad.
While not in all countries/networks 4G calling is avaliable while roaming, turning on this mode make the Apple phone not accept 2G/3G networks anymore to use for calling. Within the Netherlands 4G calling is nationwide avaliable and you could use this setting fully. While abroad, the suggestion of the workaround is a good idea if you still want to use the other parts of the lockdown..
  • apr 10, 2026 3:37 p.m. UTC
Hi ​@kolmanovich ,
This does not imply nor explain that the phone would not connect to cellular networks or that 2G/3G is necessary for that.
The 2G/3G are disabled by default when enabling Lockdown mode.
So one would have to know where to look and what to do if they travel abroad with Lockdown mode enabled.
  • apr 10, 2026 4:34 p.m. UTC
Correct,  it is a feature by Apple just to bar the phone as much as possible. In the USA calling over 4G is the only option left, so there is works fine. In orher countries,  often the 4G network is only used for data and when setting up or receiving a call, the phone is forced by the network to 3G. But if that is blocked by the phone,  callling will fail.
