Hi all, is ist possible to communicate with me klikenklaar box via internet? I would like to connect a sensor for room humidity to my klikenklaar box and check it remote.
Sensor for humidity and more connected to klikenklaar
Beste antwoord door walter.v.l
Yes, but you are going to setup a dyndns (ddns) service as the IP of the modem will change every 24 hours.
There is an option in the modem firmware to use the ddns service with the modem.
