As of 3-4 days ago my Kilk & Klaar internet has become unusable. Once every 30 second, it disconnects for about 5 seconds and then reconnects.
The speed is also much much slower than before. The router is in the same position as before and I have also tried a factory reset to no avail.
I have read quite a few posts on this forum indicating similar issues recently.
Are there any known issues? When will this situation be solved?
Hi @Deliver1068, this needs to be investigated! Have you checked your service on Bekijk de landelijke dekking van ons netwerk | Odido? How is that looking? It sounds like the signal is not strong enough. At this time I cannot help you with this question through this topic. However, I do want this to be resolved quickly, so I would like to ask you to contact us via our Social channels, Facebook (https://www.facebook.com/OdidoNederland), Instagram (https://www.instagram.com/odidonederland) or X (https://x.com/odidonederland). No social media? Then call us on 0800-0092. On our Community we can only provide you with general information. My direct colleagues will be happy to help you!
If the 5G LED turns red, it indicates that the device currently has no signal or a very weak signal from the radio tower. You may want to try moving the device to a different location — even a few centimetres can sometimes make a noticeable difference in signal quality.
Radio networks are continuously optimized and adjusted depending on network load and conditions in the area. It is possible that one of these adjustments has affected the coverage at your specific location.
Hello,
I have tried moving the router to different positions in my house, but that doesn’t solve the issues.
I’ve read a few posts that describe an issue very similar to mine. I am wondering if these were solved or not. For example:
