Hi,
I am a new subscriber of the Thuis 80 Mbps and I face very poor performance on wifi with the Huawei HG659 router.
When connected via cable to LAN1 : 75 Mbps down / 30 Mbps up (very good)
On Wifi, 50cm or 3m from the router directly facing it: 15 Mbps down / 20 Mbps up (bad download speed)
At the end of the flat, 10-15 m away from the router, in direct line of sight: 2 Mbps down / 15 Mbps up (very bad download speed)
I tried changing the channel, activating/deactivating the 5 GHz signal, activating/deactivating QoS, but nothing improves.
What can I do to have normal wifi speed?
Thank you
Wifi speed with Huawei HG659
Beste antwoord door Matthew
Hi jbd,
I would like to check for you what we can do with you Wi-Fi signal. Can you send me your postal code and housenumber in a private message? I'm looking forward to hear from you!
Bekijk origineelI would like to check for you what we can do with you Wi-Fi signal. Can you send me your postal code and housenumber in a private message? I'm looking forward to hear from you!
