No internet connection after technical issues in Amsterdam region
Hello!
I’ve been a customer for 2 and half years. I have always used my own modem without problems. At the moment, I use a Netgear Orbi router with the VLAN 300 configuration.
However, yesterday (June 3rd) I was affected by the Internet outage in the Amsterdam region. Now, the Orbi router doesn’t get a IP address from T-Mobile via DHCP. I have reset the router several times and the black media converter as well, following the guides you have.
Any suggestions you may have? I have checked the router configuration, and the VLAN is still there. I haven’t made other changes since in the past it worked fine.
Thanks in advance!
Hello @skylark
I don't rhink it's to dofficult to configure the Orbi? Could you try a reset and configure it again?
  • June 4, 2022
The best idea is first to connect the Zyxell modem again. If that also fail customer care can help.
  • June 4, 2022
Thanks Eric! I will give it a try
  • June 4, 2022
I plugged the Zyxel modem. I got Internet connection. I reconnected the Orbi router, but I still don’t get an IP address.
i will contact customer care.
Thanks again!
  • June 4, 2022
I contacted customer care. I was told only the community can help with custom routers. Do you have any other suggestions?
  • June 4, 2022
Hello @skylark
  • June 4, 2022
Thanks Waqqas. I will give it a try. At the moment I’m out of the house. When I’m back, I will do it.
  • June 4, 2022
Hi @Waqqas,
Thanks for the advice. Resetting the router to factory settings and putting the VLAN 300 configuration did the trick. Finally back online.
Have a nice weekend!
