Login Problem with my ZYXEL
  • mei 2, 2022 2:59 p.m. UTC
  • 165 Bekeken
I am using correct username and login password that are mentioned in the card fixed at the back of the modem but it does not work.
Beste antwoord door Anonymous
Hi @Gurgaze ,
Do you try to login with on the Wifi of the WebGui.
Did you already tried to factory reset the modem?
  • mei 2, 2022 3:04 p.m. UTC
Hi @Gurgaze ,
  • mei 2, 2022 3:17 p.m. UTC
@Gurgaze
The username is admin and the password is written behind Login Password on the back of your router.
For wifi it's the SSID and Wireless Key.
  • mei 2, 2022 3:27 p.m. UTC
@Waqqas doing exactly the same but it does not work.
  • mei 2, 2022 6:01 p.m. UTC
@Gurgaze
Can you perform a factory reset as @TechRacing93 suggested and try again?
