Hello, I recently changed provider from KPN to T-mobile while I am at the same adress and the same DSL connection I am not reaching to around 18mbs while in my contract it says I should be getting 50mbs or close to it which is the current maximum for my address. Please let me know if the problem is on the side of the connection of somewhere in my hardware.
I am measuring everything on the same set up the only thing that changed it the modem. the modem was replaced with the new one I recieved from T-mobile.
Thanks for help in advance
Internet 50 mbs is less then half speed
Thanks for starting this topic
-Go to www.speedtest.net/apps in your browser and download the app for the device on which you want to perform the speed test
- Please shut down all open systems including VPN
-The computer or laptop has to be connected via an ethernet cable, a speed test of a TV or gaming computer can’t be used
-Run the speed test. For the best results it’s best to test on several target servers. When you press the big GA-button, you can choose a server. Is the speed below the attainable average? Repeat the test on the same device but with a five minute intermission between the tests
-Take at least two screenshots of speed tests on different target servers and make sure your whole desktop screen is visible, so we can see the connection type (it's important that it's visible that the speedtest is made with a internet connection via a ethernet cable)
-Take a screenshot of the taakbeheer (Task Manager, on Windows) or the activiteitenmonitor (Activity Monitor on iOS):
In Windows you’ll find this by pressing CTRL + ALT + DEL; choose more details if they’re not directly visible
In Apple MacOS you can search for "Activity Monitor" from the Spotlight search box
-Take a screenshot of the IP configuration:
Windows: via the search function under shortcut “Windows + R”, type in: “cmd” and press Enter (or search for Opdrachtprompt/Command Prompt in the starting menu). After opening, type in: ipconfig / all and press Enter
Apple MacOS: via the Finder or the Spotlight search window you can open the Terminal app. Type in: /sbin /ifconfig and press Enter. This will display all connections the device has at that specific moment.
Please send me the screenshots and make sure that the mentioned steps are followed precisely. Thanks in advance!
