Installation of Home T mobile WIFI - Ziggo Old Connection
  • September 7, 2019
  • 373 Bekeken
I just moved into the new apartment where the previous tenant was using Ziggo.
I am attaching the pic of the Ziggo outlet where I want to install my T mobile WIFI.
Can you please guide me , as I cant wait for next 10 days for the technician and get this fixed at the earliest as I work remotely from home.
Thank you
Hello sid1805,
The first picture of the cable connection is only voor Ziggo.
You need the telephone connection in the second picture.
Connect the red and blue wire to the telephone connector, or use the connectionbox included in the installation box. If red/blue doesn't work try orange/white.
Regards, Marcel
  • September 7, 2019
  • September 8, 2019
There is another slot in the living room - which I tried but there is no Internet signal in the modem when I insert the wire.
Pictures attached.
Marcel MCi
Forum|alt.badge.img+2
  • September 8, 2019
Hello sid1805,
Regards, Marcel
yalerta
  • September 8, 2019
As the red and the blue wire deep down inside seems not connected to anything use the orange/white connection
If you have a telephone plug, the 2 marked holes are the connection to the orange and white from the socket.
