I just moved into the new apartment where the previous tenant was using Ziggo.
I am attaching the pic of the Ziggo outlet where I want to install my T mobile WIFI.
Can you please guide me , as I cant wait for next 10 days for the technician and get this fixed at the earliest as I work remotely from home.
Thank you
Installation of Home T mobile WIFI - Ziggo Old Connection
Hello sid1805,
The first picture of the cable connection is only voor Ziggo.
You need the telephone connection in the second picture.
Connect the red and blue wire to the telephone connector, or use the connectionbox included in the installation box. If red/blue doesn't work try orange/white.
Regards, Marcel
Bekijk origineelThe first picture of the cable connection is only voor Ziggo.
Regards, Marcel
