Hello,
I have Fiber optic connection for 1000mbps.
I have 3 floor house and therefore decided to go for Xiaomi Mesh AX3000 (2-peice) setup. Don’t want to go for Subscription package offered by T-mobile.
At first I thought of replacing it with the T-mobile router but for some reason when I plug in the lan cable to WAN port of Xiaomi it doesn’t detect any internet. So I decided to use the T-mobile Router and then use lan cables to connect the Xiaomi Mesh system on it.
But then I get two different wifi netwroks one which is offered by T-mobile router iteself and then another one with Xiaomi.
But that kills the purpose of having mesh system because this way it is not really making a mesh but simply working as WIFI extender but with two different networks.
Do you guys have a suggestion what could I do to fix this?
Apart from this I am not really getting the speed of 1000mbps.
Its hardly touching 400 mbps on wifi.
