Subscription Plan not updated
I moved to new place and my subscription also was upgraded from 50 Mbps to 1 Gbps however today after activation when I test the speed https://www.t-mobile.nl/thuis/internet/speedtest I still get around 40-50 Mbps upload and 20 Mbps download. What could be the problem ?
Hello @yogesh.padharia
You have a Fiber connection at the the new address?
Can you test the speed with a laptop/pc directly connected to the router with the Ookla speedtest app and a CAT5E or higher internetcable?
Do you also see 1000 Mbps active in your T-Mobile thuis account.
  • 22111 reacties
  • 28 oktober 2022
  • 9 reacties
  • 28 oktober 2022
@Waqqas Yes I see 1 Gbps subscription in my account and also 1000 Mbps on the Router WAN port.
Even on laptop directly connected to the router I see similar speed as wifi.
Lisa
  • 5725 reacties
  • 28 oktober 2022
Hi @yogesh.padharia, first of all: I hope you're enjoying your new home! 😊 Thanks a lot for notifying so we can help you. Can you please share the screenshots of the wired speedtests from the Ookla speedtest app? This way we can start an investigation. Are you also using a router of your own or do you only use the equipment of T-Mobile?
I want to ask you to change the current UTP-cable for a different one to check if this makes a difference. If this doesn't solve the issue, please try another LAN-port on the modem. The easy thing about the Zyxel modem is that you can use all the LAN-ports for internet. I love to hear from you so we can fix this.
