Zyxel wifi extender not working...when connected with lan cable then power led is orange
  • October 9, 2026
  • 47 Bekeken
Zyxel wifi extender not working...when connected with lan cable then power led is orange. help me in setup my wifi extender properly...also I am not able to login to admin portal of Zyxel model, getting passord wrong error message
Hello ​@kllerkapil
Here you can see the correct way of setting up a WiFi extender:
https://www.odido.nl/service/bestelling/internet-tv/installeren
Maybe try it after performing a factory reset of the extender by pressing the reset button for about 5 seconds using a small object.
6 reacties
  • October 9, 2026
Hello ​@kllerkapil
  • October 9, 2026
Thanks for providing step..let me try these steps to connect wifi extender.
  • October 9, 2026
i performed action mentioned and got stable orage led light with other 2 greeen led light..bbut when i am moving extender to other place where is require wifi there i am not getting any light in signal strength..only having green light for power and wifi icons..
  • October 9, 2026
​@kllerkapil
Do you have 2 networks on your router perhaps, 1 for 2,4 GHz and 1 for 5 GHz?
This way the extender will not work, Easymesh must be enabled.
  • October 9, 2026
yes..i have 2 netwroks..2.4 and 5 ghz as it was splitted by customer care person...so how to proceed now?
  • October 9, 2026
​@kllerkapil
Gi in you browser to 192.168.1.1, log in with admin and the Login Password behind the router.
In the menu go to netwerkinstellingen, draadloos, Easymesh, tien it on and try to connect the extender again.
