Zyxel T-56 Power light blinks rapidly but no WiFi
  • jan 14, 2026 5:41 p.m. UTC
  • 57 Bekeken
Hello,
My Zyxel T-56 modem/router from Odido is not working.
The power light keeps blinking and Wi-Fi does not appear, even after waiting for a long time.
I have tried restarting the modem and doing a factory reset, but the issue remains.
The modem does not start normally and there is no internet connection.
Could you please help check this problem or arrange a replacement?
Thank you.
Hello ​@Vladyslav
Looks like the router is stuck. Fill in all the privé fields in your community profile so a moderator can send you a replacement.
  • jan 14, 2026 5:46 p.m. UTC
Hello ​@Vladyslav
  • jan 14, 2026 6:13 p.m. UTC
​@Waqqas done, waiting for a moderator
  • jan 15, 2026 9:42 a.m. UTC
Hey ​@Vladyslav, welcome to our community!
Thank you for bringing this up. This is indeed a known issue that is currently being investigated. It appears to be caused by the transition from ACS. I would like to add you to this investigation. I see that you have filled in all the details, but the last four digits of your IBAN do not match your subscription. Would you mind changing them? Then I can add you to this investigation and they will do everything they can to resolve this as quickly as possible.
