Wifi problems
  • mei 23, 2025 9:32 a.m. UTC
  • 51 Bekeken
Hello,
I have the Zyxel Wifi extender with 2 repeaters, one placed on the first floor and one on the second floor.  Recently I have been experiencing bad quality on my work Skype calls particularly when there is a large audience and someone is presenting. I have a wifi analyser on the phone and the connection looks OK. I looked in the router Wifi admin and usually the second floor repeater connects to the first floor and the signal seems fine. Yesterday I had the problem again, I checked the admin and my second floor was connected to ground floor (not first). My laptop then connected to fist floor and the signal was not good. is there a way to keep the connections fixed ? Thanks for any help you can give.
Hello ​@Lee Hazell
Are the repeaters connected via a cable with the router or wireless? Maybe the wireless signal between router and repeater is bad, the signal from the repeater to your laptop will than be worser.
  • mei 23, 2025 10:06 a.m. UTC
Hello ​@Lee Hazell
  • mei 23, 2025 11:06 a.m. UTC
Hello, thanks for the reply, they are connected wireless. Normally it works fine but sometimes drops and I get all sorts of weird connection combinations. I just just wondered it its possible to make the connections fixed.
  • mei 23, 2025 11:29 a.m. UTC
​@Lee Hazell
Is there a possibility to have atleast one repeater wired? Otherwise try renoving rhe repeaters and connect to the router, does that make a difference?
  • mei 24, 2025 12:53 p.m. UTC
​@Lee Hazell
Thankyou Waqqas for the support, much appreciated. Running a cable is a bit difficult to floor 1, do you think an ethernet connection over the mains would be OK ? Thanks in advance for any help you can give 👍
