Unstable and low Wi-Fi Speed
  • October 29, 2022
  • 148 Bekeken
Hi,
I have openede a similar thread earlier but I am still facing with this issue since then. Nothing changed. I am changing my channel, restarting modem and all other stuffs tested but still maximum speed that I am getting is 230-250 Mbps sometimes less as well but not more then 250 in general.
I tested my speed via wired connection as well as 5GHz wi-fi too. But it is the same.
Earlier, last year which was 2021 somewhere, I was getting 600-700 Mbps even it was not 1000 Mbpgs but at least affordable but now it has dropped significantly.
Coould you please help me on this ? As I did all checks from my end, followed all the tips and I know more or less all configurations of modem(s).
I have Zyxel VMG8825-T50 by the way with up-to 1000 Mbps subscription and my house/address is supported with high-speed (1Gbit) infra.
I have also tested mobile device (iOS, android), laptops (Windows OS and MacOS) both wired and via speedtest.net.
Thanks
  • October 30, 2022
Hello @ekaya
Do you only make use of the Zyxel router or do you have another router, switch or extender behind it?
You could try a factory reset of the router by pressing the reset button on the back of the Zyxel for about 10 seconds using a small object to see if it improves anything?
The best way to check your wired speed is connecting a laptop/pc directly to the router, use the ookla speedtest app so not via the website and use a CAT5E cable or higher.
Different testservers, cables and devices can also be tried.
  • October 30, 2022
@Waqqas
Thanks for your reply. Sorry, I had no time to combe back to you earlier.
I have no other router or wi-fi extender. I am only using Zyxel for tested Wi-Fi and/or wired connection. But I have a device provided by T-Mobile which is a media Converter has 3 & 4 is up and the rest are down. I recognized that it was a recommended config and applied by T-Mobile technician (or KPN requested by T-Mobile).
I did reset :( I tried with a brand-new CAT5E cable which supports 1Gbit.
Unfortunately…
Today, before my post, I tried speedtest again and now it is 280 Mbps and still low but higher than yesterday etc.. Tested under same conditions.
Thanks
  • October 30, 2022
@ekaya
Are you performing the wired speedtest on a laptop/pc? Could you also check on another laptop/pc? Running your laptop/pc in safe mode could also by tried so all the things that could reduce the speed will be minimised and then do a speedtest.
  • October 30, 2022
@Waqqas
I have tested with laptop/pc (Windows OS) both wired and Wi-Fi (5ghz). I don’t have any other laptop/pc sorry. I don’t think so this measurement could be so complicated. I only opened one page of internet browser, chrome, and tested so far. No Download and/or streaming was peformed by laptop during speed test.
Hi @ekaya, can you post three separate speedtests performed on different timestamps please? I'm curious as to what might be a contributing factor here.
Please do understand that wifi-speeds are never a given and are always dependable on thousands of factors, such as: neighboring networks, the walls inside your home, different devices, old connections, the placing of modem and/or extenders and many, many more.
