I've been having some issues with the Wi-Fi connection. The smartphones I have work fine, but every now and then my laptop keeps disconnecting from the Wi-Fi. I also tried with another laptop and I experienced the same problem. Sometimes I lose internet for 30 minutes, sometimes for 2 hours, which is too long for me, and I hope this problem can be solved soon.
Is it related to my home address? Because this is the second time I have this problem this year.
Network problems
Beste antwoord door Yu Yang
Waqqas schreef:
In your web browser go to 192.168.1.1 and log in with admin and the Login Password behind your router. Under WiFi instellingen deactivate 5 GHz.
Another option is to go to the menu > netwerkinstellingen > draadloos > algemeen and choose WPA2-PSK as the beveiligingsmodus, click on toepassen.
Thank you for your help, I will try. It's very late today. I plan to try tomorrow.
