how to connect KPN Super wifi 5 extender with odido T-56 xyzel
  • mrt 2, 2024 8:27 a.m. UTC
  • 2008 Bekeken
Hello, I have recently switched to Odido from KPN and Odido has given xyzel t-56 router. I already have 2 KPN Super wifi 5 (while color) points which now I want to connect to Odido router. Does anyone know how to connect them? I tried with KPN method, 1. Reset and wait for constant pink light 2. Connect Lan cable between router and extender and wait for super wifi to turn green.
Thanks.
Hello @Abhijeet
Both extenders will not work with the Zyxel in a mesh network, you'll have to connect both extenders and they'll create their own netwok.
See this topic on how to install them.
  • mrt 2, 2024 8:49 a.m. UTC
Hello @Abhijeet
  • apr 23, 2024 5:37 p.m. UTC
Connect Lan cable between router and extender and wait for super wifi to turn green. You should wait at least 10-15 minutes before it turns pink to blinking green and it should work with even a zyxel modem. I used to test those devices for KPN. Best is to connect it first then reset them and drink coffee. I have tested those even connected to a fritzbox and it works. But you need to keep one super WiFi connected to the router at all times.
  • apr 24, 2024 8:55 p.m. UTC
I kinda forgot. You might to change ssid and key for the led to change from pink and green. Normally the super WiFi gets info from an experia using a proprietary communication model which does not happen with odido products since they are not supported.
