geen wifi modem zyxel T50
  • January 19, 2025
  • 9 reacties
  • 140 Bekeken
Gister avond na 12 uur ineen geen wifi meer, alles geprobeerd resetten op nieuw opstarten etc. Weet niet wat het probleem nog kan zijn misschien de modem aan vervanging toe. Of toch een storing ?Hoop dat het op te lossen is
January 19, 2025
Hoi ​@joycekallenkoot, ik wil het super graag nakijken voor je! Ik kan alleen geen abonnement vinden met je e-mailadres. Zou je voor mij je postcode, huisnummer, geboortedatum en laatste vier cijfers van je rekeningnummer kunnen toevoegen aan je profiel? Dan kan ik direct aan de slag! Groetjes, Ishana
9 reacties
Ishana van Odido
  • January 19, 2025
Same with me. The internet has been fluctuating for a while now.
  • January 20, 2025
Hello ​@Rishith
Do you have a fiber or DSL connection and does the globe on the modem turn red sometimes?
If you have fiber which lights are on or blinking on the mediaconverter?
  • January 20, 2025
Hello ​@Rishith
I have a connection with 1gbps up and down speeds, not sure whether DSL or fiber, sorry. I have not noticed the globe go on and off. However, the LAN light on the media converter is continuously blinking.. not sure if that is an issue. The internet is very flaky and very disturbing.. please help.
  • January 20, 2025
​@Rishith
Than you have a fiber connecction. What exactly do you mean by the internet keeps fluctuating?
  • January 20, 2025
The internet is flaky.. it keeps dropping often.. for both me and my wife.. you can see it as the call freezes up.. This has been going on for a few days now..
  • January 20, 2025
​@Rishith
What else do you have connected wired to the router and have you tried performing a factory reset of the router by pressing the reset button on the back of the router for about 10 seconds using a small needle?
  • January 20, 2025
I have connected my TV. No i have not performed a factory reset of my router. Is it necessary? After that how do i reconfigure it?
  • January 20, 2025
​@Rishith
After a factory reset all the settings will go to default so if you have made any changes to the WiFi credentials for example, you'll need to change them again.
It's worth trying, it could help.
