internet not connecting
  • August 22, 2020
  • 8 reacties
  • 212 Bekeken
My internet was to be activated on 21st August. To date I can't access internet and the Internet button ain't blinking. I do not understand dutch well so kindly assist.
Beste antwoord door Brian
Hi @Afwamba, we’ll see to getting you online as quickly as possible! Thank you for the pictures, is this the connection where the cable comes in from the outside? It’s not 100% in the picture if this is the main connection (ISRA-point) or a split off connection from the main one. I checked the connection on our side and I cannot read the modem so it’s currently not receiving a signal. Just a check but you have connected the modem with the supplied ‘DSL’ cable in the right port? If there are other connections/wall sockets available then you coud try those. If none seem to work then let me know, I’ll send over a mechanic free of charge to get everything set up!
8 reacties
  • August 22, 2020
Hello @Afwamba
Do you have DSL?
Is your modem connected to the main ISRA where the KPN cable comes in your house or to another pont?
Can you post a picture of how it is connected? And leaving the modem without power for a minute doesn't help?
  • August 24, 2020
Hi,
Yes
i have DSL. I have tried disconnecting and reconnecting several times but still no response.
  • August 24, 2020
@Afwamba
Try removing the brown/orange wire which is connected with black and also remove him from right under so completely. (b1 to EB)
  • August 24, 2020
I tried your option but still no response. I guess it could be the modem itself or the connection socket.
  • August 24, 2020
  • August 24, 2020
Hi, Its the main ISRA-point and the only connection port in the house. Also the cables are on the right ports as indicated on the manual. Could u send a technician to help me out?
  • August 25, 2020
Hi @Afwamba, alright we’ll send over a mechanic to get everything sorted out. You should receive a message to make an appointment shortly! :slight_smile:
  • August 25, 2020
Ok. Thanks, waiting for the message
