Internet connection problem.
  • dec 12, 2018 3:21 p.m. UTC
  • 764 Bekeken
Hi I get couple days ago box with router kabels and sockets. I was trying to connect this to use internet but there is no signal. Router is working, but I do not have a signal from socket and I do not know what have I do. Could you check signal on my adres?
Thank you in advance for your reply.
Best regards,
Dominik Misztal
1 reactie
  • dec 13, 2018 3:09 p.m. UTC
Apologies for the late reply @DominikMisztal! I see my colleague already made an order for a mechanic to help with the installation. We'll get you online in no-time! ;)
P.S. For privacy's sake I removed your address from your initial post.
