Does my apartment have ISRA connection?
  • November 11, 2020
  • 9 reacties
  • 278 Bekeken
Hi all!
Moved to a new apartment without an internet connection and decided to get T-Mobile. I got my installation box today, and looks like I don’t have the necessary socket anywhere in the apartment. There is only one green coax cable that goes to the apartment. Is it Subscriber Takeover Point (AOP)? Can I use it to connect T-Mobile modem?
Thanks!
Hello @belprm
The green cable is a coax cable used for cable internet which T-Mobile doesn't use. Have you got something like one of these in your apartment?
It could also be a telephone cable somewhere which is not connected to anything.
9 reacties
  • November 11, 2020
Hello @belprm
  • November 11, 2020
Hi @Waqqas!
Nothing like this and no telephone cable too.
  • November 11, 2020
Hi @Waqqas!
Does this site say Koper/DSL ..?
https://tele2-fpi-info.fourstack.nl
If DSL is available then there should be anything in your livingroom, fusebox or maybe somewhere else.
  • November 11, 2020
  • November 11, 2020
@belprm
If you really can't find anything than it's better to let a technician have a look, wait for a moderator to reply..
Maybe it could be an option to see where you neighbours have there DSL connection connected?
  • November 11, 2020
@Waqqas
I’ve checked the staircase. There is one gray cable (and it could be just an intercom cable).
  • November 11, 2020
@belprm
Are there wires in it, red blue orange white?
There should be a white connection box in your installation package try connecting red and blue in it and if it doesn't work try orange and white.
  • November 11, 2020
@Waqqas
This cable is on the public staircase, and it doesn’t go to my apartment. I don’t know where it starts or ends.
  • November 11, 2020
@Waqqas
Ah okay, I guess it's not the cable you're searching for.
