Direct fiber connection to Ubiquiti
  • dec 21, 2025 11:54 a.m. UTC
  • 73 Bekeken
Hello, is it possible to bypass Odido gear and connect directly to my Ubiquiti UCG Fiber via an SFP+ port? I currently have Huawei OptiXstar HN8010Ts-20 XGS-PON.
Additionally, is it possible to return the Odido modem/router while retaining the service? Don’t use it and would prefer not to store it
You can only send it back after you stopped the subscription.  You need the equipement when calling the customer care in case of an issue. They can only diagnose when the Zyxel is connected.
Of course you are allowed to use your own equipement in the meantime.
Hello ​@Aldas
Use this SFP stick for example, quite a few Odido users are using this one:
https://schenkict.nl/en/products/zaram-xgs-pon-onu-sfp-1
2 reacties
  • dec 21, 2025 12:11 p.m. UTC
  • dec 21, 2025 2:16 p.m. UTC
Hello ​@Aldas
