coax to glasvezel
I live on 1053TA. I am wondering, we currently have the Ziggo internet with the told Coax connection. If we switch to Odido for a better deal and faster internet, can they also replace the connection? Is there a cost?
Thanks
May 7, 2024
Hi @Harrison ,
it looks like the preparations to dig fiber into the Schimmeltraat are started. You can check the Odido  zip code portal and pre-order a subscription. As soon as they are ready to deliver, there will be a fiber brought into your house and that supports up to 8 Gbit down AND 8 Gbit UP. Where the Coax cable max UP is 100 Mbit...But if you just want a better connection against a compatative price, you also can order lower speeds. Up and down will alsoways be equal.
1 reactie
  • May 7, 2024
Hi @Harrison ,
