After 2 months of wait i am upgraded to 8Gbit/s, but my speed is 5/down 3/up
  • February 10, 2024
  • 8 reacties
  • 254 Bekeken
Dears,
I was a long time user of 1 Gbit/s fiber optic and i was receiving always 980/980.
Now after upgrade to 8 Gbit/s i am not getting more than 5 down and 3 up!
any help?
Beste antwoord door senad.aruc
Hi @senad.aruc, I see that two different appointments were made at the same time. Just schedule the appointment with Guidion to be sure, he can check everything for you!
The issue is fixed now I see 7GBPS up/down.
Thanks,
8 reacties
  • February 12, 2024
Dear Tommie of Odido can you help me plese?
Hi @senad.aruc, good thing you started a topic for this. I went straight into it for you and see that you cancelled the engineer? Do you have a reason for this? Because the engineer has to come by because you have a Point to Point connection and this has to be rerouted in the district exchange. The ONT and T-75 are then installed immediately. Then the technician should set the order administratively to complete. I will forward below a list of what needs to be done on the various technelogies. I have re-directed Guidion for you, schedule the appointment and it should be fine!
Netwerktype
Wel/Geen nieuwe ONT
Patching nodig?
Guidion nodig?
GPON
Wel nieuwe ONT
Nee
Ja, voor ONT
XGSPON
Geen nieuwe ONT
Nee
Nee
PtP
MC wordt nieuwe ONT
Ja
Ja, voor ONT
  • February 13, 2024
Dears,
any help?
Dears,
The engineer came and installed the equipment! i think they made 2 appointments so i canceled one of them but the engineer came Saturday and installed the equipment.
Thanks,
  • February 13, 2024
Ok, so if they can fix the speed issue then lets make a second appointment.
  • February 28, 2024
Hello,
Guidion visited my house today nad unfortunatly he was not able to fix the slow download and upload problem today.
At my Huawei fibr optic conferter I see that the ONT values are lower than the reference values so maybe this is the problem for the 5GB down and 4GB up slow speeds.
Can you please help me with the speed issue I have?
Thanks,
  • February 29, 2024
Thanks,
Thank you so much for this update @senad.aruc! I will inform the backoffice. Enjoy your new speed!
