Samsung TV not connecting to Zyxel T-56
  • February 17, 2026
  • 35 Bekeken
I’m experiencing a WiFi compatibility issue with my Odido Zyxel T-56 router (fiber) and a Samsung UE43TU7020 (2020) TV. The TV does not connect to the router’s WiFi network, while it connects immediately to a mobile hotspot, confirming the TV hardware is functioning properly. I have already disabled WPA3 (using WPA2-PSK only), disabled IPv6, tested 2.4GHz and 5GHz separately, manually selected channels, rebooted the router, and reset the TV network settings.
Other devices connect without any issues.
February 17, 2026
Hello ​@patchi707
In most cases WPA2-PSK is the solution, have you selected the 2,4 GHz band before applying WPA2-PSK and than connecting the tv to the 2,4 GHz network?
1 reactie
  • February 17, 2026
Hello ​@patchi707
