I set up and used port forwarding on Odido Zyxel router, but after the general internet outage in Odido Dordrecht on August 1st it does not work anymore. IP address was changed but still looks static. No any configuration change was made from my side.
Odido support says “we see your internet connection is active, cannot do anythig else”.
Does anybody experiencing the same? Or maybe maybe can advise how to connect Odido technical specialist with a knowledge of port forwarding?..
Thanks.
