Since June, without a proper internet connection / TV / phone and I'm in endless Walk or no solution.
It's incredible, I've subscribed to your services almost 3 months ago, and since then, I still haven't played a clean connection, and you guys are playing the blame game since you guys are telling me that I have to wait for the Optical Cable provider fix the issue, they have already scheduled 3 visits to my place, I've already lost 3 days of work waiting for these guys that never appears, (Today was the 3rd day that I've lost, this is costing me a lot of money). So then I'll call T-mobile again and you'll tell me the problem is with the Optical Cable, then you'll transfer me to the Optical Cable company, that will schedule a visit, and again they will make me lose my 4th day of work waiting for them, as they will not appear again, sometimes they call me and give me an excuse and often is that they had a busy day, but seriously, every time? And if you know that will be busy just call me and let me go to work. I don't know what to do anymore, maybe Cancel your services would be the fix. Since it's not my fault that the Optical Cable company doesn't fix it whatsoever. I'm able to connect using and old Media Converter but the connection is shamelessly slow when it works. I'm pissed or. I haven't canceled everything yet because I have cellphones in the same address to get the discounts, but if I knew the hard times that I would have after subscribe to your services I would have picked another provider. t know what to do anymore, maybe Cancel your services would be the fix. Since it's not my fault that the Optical Cable company doesn't fix it whatsoever. I ' m able to connect using and old Media Converter but the connection is shamelessly slow when it works. I'm pissed or. I haven't canceled everything yet because I have cellphones in the same address to get the discounts, but if I knew the hard times that I would have after subscribe to your services I would have picked another provider. t know what to do anymore, maybe Cancel your services would be the fix. Since it's not my fault that the Optical Cable company doesn't fix it whatsoever. I'm able to connect using and old Media Converter but the connection is shamelessly slow when it works. I'm pissed or. I haven't canceled everything yet because I have cellphones in the same address to get the discounts, but if I knew the hard times that I would have after subscribe to your services I would have picked another provider.
Since June, without a proper internet connection/tv/phone and I'm in endless Loop of no solution.
Beste antwoord door Brian
Hi @Kaat33 , uiteraard help ik je graag! Ik begrijp dat je problemen hebt met een specifiek apparaat? De Huawei modem gebruikt inderdaad zowel 2.4 Ghz als 5 Ghz. Als de doorbird hier niet mee overweg kan, dan kan je eventueel één van de twee signalen een andere naam geven zodat je ze kan scheiden. Daar vind je hier meer informatie over. Ik zie in eerdere meldingen dat de verbinding weg zou vallen, is dit alleen met het gebruik van de Doorbird of speelt dit ook met andere apparaten? Met inloggen op het modem bedoel ik dat je verbinding maakt met het modem zelf. Dit kan je doen door 192.168.1.1 in je browser in te typen. Ik hoor graag van je!
Bekijk origineelEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
