Since this morning, my internet connection at home is working pretty slow. Every single webpage I try to load takes like 30 second. Sometimes it doesn't load (I got a message saying “Your internet connection was interrupted”) and I need to refresh in order to start loading again. Do you know if there is any issue with ODIDO in Delft? I ALRE
Internet speed low
Hello
Does restarting the mediaconverter and router help?
Is the speed the same on all devices wired and via the WiFi?
You can also try to change internet cables or perform a factory reset of the router.
