Installation of Home T mobile WIFI - Ziggo Old Connection
  • September 25, 2020
  • 667 Bekeken
HI All,
I just moved into the new apartment in Den Haag where the previous tenant was using Ziggo.
I am attaching few pics of the Ziggo outlet (Braun Telecom POA 01 - UPC) where I want to install my T mobile WIFI. I received few connector in TMObile Box which i received and also check TMobile connection setup webpage showing 3 type of connection but seems nothing like what is installed in my apartment.
Can you please guide me, as I can’t wait for next 10 days for the technician and get this fixed at the earliest as I work from home these days.
Regards
Kapil
Hello @kllerkapil
The pictures of the outlet you are showing is not used by T-Mobile.
Try to look for something like this or something similar in your fusebox, living-room or somewhere else:
It could also be just a telephone cable, the ISRA needs to be repaired then.
Hello @kllerkapil
Thanks for your reply..but i fear there is no such type connection available in apartment. I checked with Apartment owner also but not available.
whats else can be done now?
You were able to order a DSL subscription so it should be somewhere I guess,  maybe it needs to be repaired. Then it's better to let a mechanic have a look.
  • September 28, 2020
Thanks Waqqas...i have raised complaint with T-Mobile...they saying they will inform KPN to do installation of point for connection...it will again take 1 week minimum :( . thanks for all your support.
Great :)
Hope everything goes well and as planned 👍
