Hello! I moved to a new house. It seems that there are some in wall ethernet cables connecting the electric cupboard with the rooms. However when I plug my computer in the room socket is not working. I suspect in wall cables are old and need to be replaced. Does odido offer the service to replace im wall cables? If so, do you know how much it cost? Thanks!
in-wall cable replacement
Hello
The installation partner of Odido can do this for you, see this page for the costs:
https://www.odido.nl/service/bestelling/internet-tv/installeren/installatie-door-monteur
