Hi, I found recently that following ip addresses are reachable via icmp but when you try to established tcp connection - no response:
95.181.181.106, 95.181.181.213 (actually i have many others which are also not reachable)
ping 95.181.181.106
PING 95.181.181.106 (95.181.181.106): 56 data bytes
64 bytes from 95.181.181.106: icmp_seq=0 ttl=57 time=50.632 ms
64 bytes from 95.181.181.106: icmp_seq=1 ttl=57 time=50.195 ms
telnet 95.181.181.106 443
Trying 95.181.181.106…
Via vpn or odido mobile tcp connections work fine, all problematic websites are working
Can someone check if these ip addresses are reachable from other odido ip/subnet?
