Je kan op dit moment niet toevoegen. Probeer het later nog een keer.
Previously I had both my mobile phone subscription and my home internet under the same account.
When I moved last year I’ve got a new internet subscription, but since then I’m not seeing that subscription under my account.
If I try to link the internet subscription, I’m getting the ‘Je kan op dit moment niet toevoegen. Probeer het later nog een keer. Ga terug’ error message.
Could you please link my internet subscription to my original odido account, thanks’
Hi ​@Tyra3l, I will help you with this for sure! No worries. If I understand correctly, your mobile subscription is currently visible, but adding your Internet+TV subscription doesn't work. Are you a 100% sure that all the details match on both subscriptions? This is mandatory. If so, please add your full name, street name, zipcode, house number, date of birth, your mobile number and the last four digits of your bankaccount to your Community profile. This way I will check this for you ASAP!
  • May 25, 2025
Hi, thanks, I’ve filled out my profile with the details.
The details(name, adress) should be matching on both subscriptions.
Teresa van Odido
Thanks for your efforts! ​@Tyra3l
I've immediately looked into our system. However, I see that your old subscription is not linked to the account either. All your other details are matching with your Mobile account, so this can't be it either. I really want to solve this for you, so I asked for the help of the specialists' team. I'm sure they will be able to resolve this issue for you, so you can view all your Odido subscriptions in one place.
Do note that the processing time is 14 days. If you want to know anything about you at home subscription, or if you want to change anything. Let me know! I'll gladly take a look for you. Questions? Don't hesitate to ask. I'm always here to help you!
