same subscribtion on mobile phone and mobile modem
  • 21 november 2022
  • 32 Bekeken
Hello T-Mobile community,
I want to use my T-Mobile subscribtion on my phone and on my mobile modem simultaniously.
Is it possible if I buy e-sim for my mobile phone, and will use normal sim in mobile modem?
or i need secod normal sim and install it in mobile modem?
Thank you.
Hello @since81
The best option for you would be to subscribe to a mobile subscription for your mobile and subscribe to a data sim only subscription for your mobile modem, both simcards will work independently from each other.
T-Mobile data sim only
  • 21868 reacties
  • 21 november 2022
Hello @since81
  • 21 november 2022
Hi @Waqqas ,
thank you this is a goid option, just ordered it.
Thank you.
  • 21868 reacties
  • 21 november 2022
@since81
Did you also look at 4G voor thuis? It's also an option for internet at home via the mobile network.
https://community.t-mobile.nl/4g-voor-thuis-568/info-het-vernieuwde-4g-voor-thuis-is-hier-324496
