Internet connection performance is too slow, Odido is not helping
  • 12 oktober 2024
  • 8 reacties
  • 295 Bekeken
I’ve become Odido customer about 3 weeks ago, hired Internet for house 2Gbit/s. Since the very beginning the internet speed does not even reach half of the contracted speed. Contacted the support, shared requested images from speedtest barely reaching 300Mbit/s. Days later the support asked for more data using, surprise, using cable. It is hard to imagine contracting 2Gbit/s, the Wifi plus product, and have to use this combination with cable connected to the devices. In my street we are using fiber. If someone could please help, infortunatelly I can no longer cancel contract without a fee.
Uitgelichte reactie
12 oktober 2024
Hello @tochsendorf
You are getting 300 Mbps via the WiFi? Please prrfdorm the steps as described here and share the screenshot in this topic.
Replacing the cable between mediaconverter and router might also help.
8 reacties
  • 22129 reacties
  • 12 oktober 2024
Hello @tochsendorf
  • 13 reacties
  • 13 oktober 2024
There it goes, it does not look much better using the app.
PS. This is 182Mbps with a connection paid of 2Gbps.
  • 13 reacties
  • 13 oktober 2024
And using Odido Amsterdam.
  • 13 reacties
  • 13 oktober 2024
Ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
    options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
    inet 127.0.0.1 netmask 0xff000000
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=400<CHANNEL_IO>
    ether 30:35:ad:ae:45:98
    inet6 fe80::406:7b52:2178:86c1%en0 prefixlen 64 secured scopeid 0x4
    inet 192.168.1.41 netmask 0xffffff00 broadcast 192.168.1.255
    inet6 fd1d:fe4f:b3c9:431:96:8f0a:e0da:4dbd prefixlen 64 autoconf secured
    media: autoselect
    status: active
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    options=460<TSO4,TSO6,CHANNEL_IO>
    ether 82:18:40:22:69:00
    media: autoselect <full-duplex>
    status: inactive
pktap0: flags=1<UP> mtu 0
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=63<RXCSUM,TXCSUM,TSO4,TSO6>
    Configuration:
        id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
        maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
        root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
        ipfilter disabled flags 0x0
    member: en1 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 5 priority 0 path cost 0
    media: <unknown type>
    status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
    ether 02:35:ad:ae:45:98
    media: autoselect
    status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484
    ether ca:6c:fc:7a:e3:e0
    inet6 fe80::c86c:fcff:fe7a:e3e0%awdl0 prefixlen 64 scopeid 0x9
    media: autoselect
    status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    inet6 fe80::c86c:fcff:fe7a:e3e0%llw0 prefixlen 64 scopeid 0xa
    media: autoselect
    status: active
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::5d8a:4775:8acd:6ad6%utun0 prefixlen 64 scopeid 0xb
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
    inet6 fe80::838e:8f3c:9723:5d3%utun1 prefixlen 64 scopeid 0xc
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
    inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0xd
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::803e:ccc6:bedd:e231%utun3 prefixlen 64 scopeid 0xe
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::214:dea9:ed4c:dab%utun4 prefixlen 64 scopeid 0xf
  • 13 reacties
  • 13 oktober 2024
Forum|alt.badge.img+11
  • 14854 reacties
  • 14 oktober 2024
Hi @tochsendorf, could you run a speed test to our standard? Could you also do a powerflip? I cannot get a proper line measurement.
Powerflip
  2. Wacht minimaal 10 seconden
Speedtest bekabeld - De instructies hiervoor vind je op onze website.
Please follow all the steps carefully, please share the screenshots in the topic instead of to our email. We cannot process an application with missing steps.
  • 13 reacties
  • 20 oktober 2024
Powerflip
Hello @Tommie van Odido I’ve done the powerfilp as oriented. After the connection came back, the speed was the same disapointing one. However, after that, I did one more trial and disabled 2,4Ghz and tried to use only 5Ghz. Then I saw an improvement, the connection speed was reaching near 1Gbps on the wifi at a distance of 50cm of the router on a somewhat new iphone. Good thing to see the improvement, sadly I am paying for 2Gbps.
About your question “could you run a speed test to our standard”, no I cannot. I can only provide what I have already. Also it is concerning A LOT that I lose my right to privacy, sharing screenshots of my data and my devices in a shared environment, and if I don’t, apparently I don’t get support from you. Is that correct? I need to give up on privacy to get support?
All I want is a technician to come to our place, run its tets and confirm whats obvious from day 1 or get it fixed. If you guys cannot do this, please help me to cancel this contrat without a fee since you cannot provide the service you sold me.
Thanks
  • 14854 reacties
  • 21 oktober 2024
A ticket has already been opened for you with the technical department @tochsendorf. We have asked to reboot the access switch in the hope that this will work.
