Since 3 days my wifi is dropping for every 5 minutes.
I did poweroff couple of times but not helpful
Hi
Hi Team,
Still i have issues with wifi dropping.
Hello
Do you have a Fiber or DSL connection and is the wired connection also dropping every 5 minutes or is it stable?
DSL.
Wired connection is fine.
Wireless is not working properly.
Tried all the options (reset , poweroff ) but no use.
Can you remove all other devices which are connected with a wire to the modem and check the WiFi then?
Which modem do you have?
Yes I did .
Zyxel T-54.
still wifi is dropping
Hi
Its been a week almost ,my problem is not solved.
Its hampering my work.
I hope you will resolve it soon
