help with connection after moving
Hello,
I’ve been trying to use the internet at my new house, I connect to the WiFi (both internet and WiFi are blinking) but I get a no internet connection message. We kept the connection we had at our previous house and confirmed that it has been activated. Can you perhaps help with that?
thank you!
Hello @iruini
Do you have a Fiber or DSL connection?
If you have Fiber, which lights are on on the converter and in case of DSL is your modem directly connected to the main ISRA?
  • 21529 reacties
  • 7 december 2021
Hello @iruini
  • 7 december 2021
Hello,
we have fiber, I see all green besides speed and FO.
  • 21529 reacties
  • 7 december 2021
@iruini
Than it should be working, the internetcable is going to the WAN port of your modem?
On the converter there are 6 switches, 3 and 4 should be on or 1 and 6. You can try the other combination but remove the power first.
  • 7 december 2021
Internet cable goes to WAN indeed.
Switches 3 and 4 were on, I tried 1 and 6 but then the internet light went off after I restarted the router so I switched in the 3 and four again.
I’ve attached a photo of the converter, is there something else I can try? The internet light is blinking, should it be stable?
When I try troubleshooting with my laptop it says dns not responding, don’t know if it helps.
  • 21529 reacties
  • 7 december 2021
@iruini
Which modem do you have? On the Zyxel the globe should be steady green.
  • 7 december 2021
It’s the huawei hg659.
power and wan are steady green, WiFi and internet flashing
  • Oud Moderator
  • 3618 reacties
  • 8 december 2021
Hi @iruini,
Congratulations with your new home, I'm sure we'll get the internet to work soon!
Based on what you've already tried: could you perform a factory reset on the modem? If you don't get it to work via this way I would love to help you out by sending a technician over. However, you did not link your Community account to your Thuis subscription yet and thus I cannot reach your dossier. Could you send me the following details via a private message (by clicking “stuur bericht” on my profile) so that I'll be able to help you out in a more adequate manner:
  • Zip code and house number.
  • Your date of birth.
  • The last four digits of your IBAN.
I'll try to get back to you as soon as possible!
